Quick voltage question
Team MAF
IN
Wondering why my voltage stablizes at different levels, anywhere from 13.7-14.5.Its because the batteries are being charged right and since the batts are taking volts/amps its causing my overall voltage to drop .4-.7v correct? //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
A battery or two charging doesn't cause that much of a load on an alternator. Do you have an electric motor fan or is the AC compressor kicking on when the voltage drops? You may have high resistance between your postive/negative under the hood or at your amp. I'd do the big three as well.
Team MAF
Team MAF
IN
jrwalte
vegang
vegang
