Quick Question
this question is so vague. first at what ohm load do you need 800 watts? what is your budget? what do you mean buy remote? remote gain? remote bass knob? you don't need a remote bass or gain knob as they do nothing but harm. we need more info to suggest amps
I think Iceteebone was just saying that alot of people that use the gain/bass knobs view them as purely a volume knob, and don't take into account that if turned up to much can send a clipped signal to the sub or speakers, which can ruin them.
However, I find myself using my bass know quite a bit to level out whatever music I am listening to...as most music (especially different radio stations) is recorded at different levels, some with more emphasis on bass, and some with less.
You still need to give a budget though. There are proabably hundreds of amps out there that will do that power. Help us help you.
Thanx but for some reason i dont really like infinity's amps.........Im now tryin 2 figure out if im gonna use somethin like a 1000 watt mono amp and just hook it up 2 tha 2 subs or if im gonna go with a two channel like a Rockford 8002...............If i was gonna get a mono amp which one would u peick outta the three:
Hifonics BX1500D
Phoenix Gold Tantrum 1200.1
Hifonics BX 2005D
Im still really open to any suggestions though
I i mean its rated at 800 RMS at 2 ohms..........Remote bass or remote gain..............How do they do nothing but harm?
Directed 1500D
Power ratings
Rated Power @ 4 ohm: 425W x 1 RMS
Rated Power @ 2 ohm: 800W x 1 RMS
Rated Power @ 1 ohm: 1100W x 1 RMS
Dynamic Power Rating 1500 Watts
General
Class d (digital amplifier)
S/N > 80 dB
Frequency Range 20-250Hz
Damping Factor: 50 (typical)
Input Sensitivity: 150mV to 8V
Crossover: variable 18dB low-pass
8db Bass EQ
RCA Output
Protection circuits: Thermal, Short circuit and DC offset
Real Soild Amp
You can pick up a factory refurb for around 200, or a new one for 300-350
bdawson72
Finally Has Bass Again
bdawson72
434/804, Virginia 15's:Yezzir
bdawson72
michigan born
    May 14, 2026
michigan born
    May 14, 2026
