Quick Question about Wiring Woofers in Series/Parallel.
Jer510
Slap Addict
When you wire woofers in series coils/parallel woofers, the bridge on on sub is a negative wire and the bridge of the other sub is a positive wire right?
Example:
Thanks
Same sub
Pos of one coil to neg of other coil for jumper
Same on other sub
Then unused positives from both subs to pos on amp
Unused Negatives from both subs to neg on amp
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so on one sub, the bridge wire is a negative speaker wire that connects the positive and negative coil. and on the other sub, the bridge wire is a positive speaker wire that connects the positive and the negative right?
Well it doesn't matter if you use the wire labeled for positive or negative.
But to answer your question yes //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
OOOHHHhhhhhhh................................... that doesn't matter. If you want to sure //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
once again, what he said //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks. could the reason why my subs aren't loud enough for me be because I am using stock speakers and I can only use a good 1/3 of my head units volume before my speakers distort? My volume goes to I think 35 (alpine headunit) and I usually only play around 15-20.
Jer510
Slap Addict
Jer510
Oakland, CA
schackel
