QUICK Pick Guys help..
LOL
I'm not that crazy, I figure those numbers are WAY over rated, and the amps would heat up tremendously trying ti push that out.
Its easier to have too much power, and turn the gains down, and keep a cool amp than not enough?
I really only want about 100-150 a channel.
I'm with Mike although I haven't used any Cadence amps. I have also heard that Opti is the only new line of amps that Lanzar makes worth a ****.
Check this one out. Good quality and in the same price range.
http://cgi.ebay.com/NEW-ROCKFORD-FOSGATE-POWER-T3002-838-WATTS-RMS-2-CH-AMP_W0QQitemZ190211153557QQihZ009QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The T3002 is the most under rated amp Rockford has ever made. Birth Sheets on it show:
# ACTUAL POWER OUTPUTS AS MEASURED BY ROCKFORD
# 223 Watts x 2 RMS @ 4 ohms
# 315 Watts RMS x 2 @ 2 ohms
# 346 Watts RMS x 2 @ 1 ohms
# 838 Watts RMS x 1 @ 2 ohms
The T3002 Birth Sheet I used to own actually showed 932 RMS @2 ohm bridged. That thing was a beast for what they rate it at.
Really liking that Rockford amp there..
2 Of them would be perfect I think, as I am hopefully changing my order and not ordering rear 6X9's for my car, just the PG RSD's for the front.
One amp for the PG's up front, and 1 for my sub..
Bryce
00' Si
Bryce
Amherst, NS.
mdillon
michigan born
    May 14, 2026
michigan born
    May 14, 2026
