QUICK opinion needed
maldecido33
MSEE
I have a 12" AA Avalanche; box is 2 cu ft net. tuning right at 33 Hz.
should I go with one 4" precision port (~12.56 sq in of port), or two 4" precision ports (~25.1 sq in of port)
need this quick, i have the box built, i just need to throw in either one, or two, ports. :)
thanks
i've been told by reputable sources the avas can handle up to around 1400w without starting to bottom out
As stated, it really depends on the enclosure. To extend onto that though, don't be so hasty to run 1200 on it. Run the amp at 4 ohms and you'll be very pleased with the results //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif (ps, they really don't gain much output going from ~450 to 1200 watts)
As far as the port situation, if your box is 2 cubes, look to have ~24-30 inches of port area...so two ports would be the way to go over one.
maldecido33
MSEE
maldecido33
Lubbock, TX
swimfreak26
