Quick help with spark plugs
89montero
I'm installing an MSD 6a box and also need to replace my plugs. NGK v-power and g-power plugs are supposed to work the best on my engine and I have had alot of people recommend the G-power.
Can I use the G-power plugs with an MSD ignition? I read that since the msd sparks multiple times and is stronger that it will burn out the G-power.
Any info on this?
There's only a 50cent difference in price so I don't care about that.
Thanks
I don't see why the hell an ignition box would spark more than once. The explosion is instantaneous, and expends a large majority of the fuel. A second spark would only burn the little bit of remaining fuel, and result in a backfire... And the plugs should be just fine. Just make sure and gap them to the tightest spec recommended for your car.
89montero
89montero
Seattle, WA
Ferendon
