1992 Eclipse..can Anyone Answer My ?
Can U Swap A 1.8 Engine With A 2.0 Turbo Engine Is The Bolt Pattern Any Different And Will I Need A New Transmission???
Honestly.. It's going to be cheaper + soooo much easier to just start with a Turbo DSM to begin with. You'll have to find a 6-bolt 4G63T with the FULL harness. You can use a 7-bolt, but I'd stay clear of them as they tend to crankwalk quite often( and it's just more work). Then you'll need to route a new exhaust system and find a sufficient fuel supply. You can use the same ******.
-Bill-
that's true, there's a good clean awd 91 shell sitting here, nice paint, intact harness and everything, just needs engine and *****, $500. they're everywhere if you look. people can't keep them running for some reason. dumb kids....
They can't keep them running because they do this.. Almost any idiot with a turbocharged vehicle hears that they produce these things called 'boost controllers'. They figure.. "More boost, more power" without even considering the fact that tuning and more fuel is also needed. Hook it up, "Lets see what 30psi will do with nothing but a CAI"... Dun dun dun.. Another one bites the dust.. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-Bill-
-Bill-
SO YOU SUGGEST FINDING A ECLIPSE WITH A 2.0 AND BUILDING OFF THAT INSTEAD OF SWAPING ENGINES?
No... the 420a is a 2.0. The 4g63 is a 2.0. And they are worlds apart.
He's suggesting find an already-turbo DSM. And as far as they "reliability issues" go with DSMs. They're self-perpetuating myths. As stated above, people think they can simply pump the boost to 30 psi, and do 6k clutch drops cause "it's AWD, it's made to launch". Any DSM you find is gonna be
1)babied --- very rare... VERY.
2)built --- expensive, and never buy someone's project
3)busted --- typical, and very cheap. The perfect project.
p3fosgate-impal
chicago,il
Ferendon
