Quick 880prs question (not another noise question)
POLKAT
I have been trying to figure out how to get the separate left/right 16 band eq. All that I can seem to get is the "regular" 16 band eq that does left/right together. I have torn apart the manual trying to figure it out. The only mention of it that I can find is in the "specifications" part in the back.
It's probably something really simple. For some reason I can't figure it out. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Thanks for your help.
Doh!
Thanks! I knew it was something simple.
//content.invisioncic.com/y282845/emoticons/youreawesome.gif.a27e190c662afa8e2be5686b27bd1659.gif
Another thing somewhat over looked, the same way you achieve the L/R separate EQ, you can also set it that the left and right cross-over points and slopes can be adjusted independently. A bit over kill, but cool none the less.
//content.invisioncic.com/y282845/emoticons/phatyo.gif.0c0e21b4fcf7bc51bc9a8375a5ca4d49.gif
That is a good thing to know. Being able to have different x-over freq. and slopes on each side could help even out peaks and dips in response that happen only in one side of the vehicle due to that side being more or less off-axis than the other.
I love the 880prs. It's amazing what you get for the money.
Yea, I was messin with it one day, was like hmmmm I wonder if this works, and it did.
The time spent on it for the minuscule difference didn't seem worth it to me, because my setup already sounds good enough as it is, and decided to leave well enough alone. However, I found myself messing with the TA again the other day, I thought I had it set up pretty well the last time, but I managed to do my self one better this go round.
POLKAT
POLKAT
Ohio
bass_lover1
