Question on Wiring Older HU
mlinarz
Pioneer HU-14 only has 1 preout, which is currently running to amp that drives sub. All other speakers are driven by powered outputs from HU.
If I put in an amp to drive the other speakers, should I split the preout and send one leg to amp sub and one leg to other speakers amp? If I did this, should I put in a line driver?
Or is there a better way?
well, i believe there is a 2 in 1 rca adapter you can get... check radio shack or a local shop... but the easiest solution for this is to buy a dual preout HU if you do indeed decide to get the amp..
mlinarz
mlinarz
San Diego
bri487
