Question on setting gain
87linkin
Ok, I am about to set my gain with dmm.
I have a mono block amp but it has 2 sets of speaker terminals. When I set the gain it don't matter which + and - I stick the dmm leads to does it? After all they are connected internally.
I am after 3500 watts. My amp Will be at .5 ohm. I will just turn my gain up until I see 41.83 volts ac right? Is that what i'm looking for?
Setting the DMM to AC (Alternating Current) means it doesn't matter where the + and - leads are located. Unless you are playing a test tone, just be prepared for the readout to be jumpin' all over the place. And if you are playing a test tone, don't start with it cranked all the way up or you are gonna fry somethin' right quick. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Also, refer to the amp manual as to the highest voltage reading based on the impedence of the driver.
87linkin
87linkin
alabama
AlterEgo99
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
