Question in regards to AMP settings HELP!
Hello All,
Ok so yes im a newbie here and kinda a newbie when it comes to setting up car stereo's.
By the way this is all in a 2007 scion tc.
Here is what i have hooked up.
1. Stock pioneer HU
2. Exile S500.1 Amp
Amp is rated at 500x1 at 2ohm rms and 1000x1 max at 2 ohm
3. Kicker L5 in ported box
Kicker 12 inch sub is rated at 600watts rms and 1200 watts max
I have it wired down to 2 ohm for maximum output.
My Question here is i need help setting the settings on my AMP to get the best sound/most bass and be able to get good high and low bass.
My choice of music is as follows
1. 75% Rap
2. 25% Rock/Alternative
Here is what i have all the settings at currently on my AMP
Bass Boost = 12db
Subsonic = Approx 30hz
Config - LP
Freq = Approx 150hz
Level = Max
Then i have a remote bass knob that i usually have all the way up.
DCtC
I will try the settings you mentioned i sure appreciate it alot.
And as far as level = max and your WTF responce lol
I dont know what it is all it says on the amp is Level?
if you want i can see if i can upload the pdf manual for the Amp?
scionguy
scionguy
Washington State
LosIsATool
