Question about car audio wiring...
Hi, i have a 2000 Nissan Sentra and im trying to install a Boss CD-3125R stereo into it. There are many different wires and im not sure how to connect them. Ive searched all over the internet for a wiring diagram, but i cant find any for my car year... what should i do? Or if anyone here just so happens to know the wires, that would be great:)
ya, not the best headunit, but if thats all u can afford thats the best, im sure it will work fine, they have kits for you vehicle at meiejer/autozone/walmart and u just match colors
You need the Metra 70-7550 wire harness. If you cut off the factory harness you fawked up and you need to reconnect the harness with a soldering iron and heat shrink - or pay a tech to fix it.
Metra Electronics - Dealer Parts Warehouse
you should also have a mounting kit like the Metra 99-7414
http://metradealer.com/files/products/INST99-7414.pdf
from there, you need to solder/heat shrink, or crimp the wires from the Boss harness to the Metra harness - simply matching colors. make sure these connections are solid - you'll need proper tools. Use only crimp connectors, do not use home wiring twist on caps.
cjrachelle88
cjrachelle88
Raleigh, NC
keep_hope_alive
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
