Question about amp.
  • 2
Cmberges1
I've looked everywhere (even the manual) and am stumped so far. The amp is JL Audio JD400/4. My question is can i run a component set (4 ohms) on the front 2 channels and a sub (2 ohms) bridged on the other 2 channels? Should be a simple one and I should know the answer but I'm at a loss. I've tried to search everything about the amps wiring and can't find if the amp is 2/3/4 or what. Don't ask why i bought the 4 channel amp (guess I thought about rear speakers before I realized the truck didn't have rear speakers). Anyways, help or ideas?!?!? Thanks
It is stated in the manual that 4 ohms is the minimum for bridged channels. I would not run a 2 ohm load on the bridged channels.
Page 10 -
655
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Haven't 100% landed on which one, but I am down to those two
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
Cmberges1
Cmberges1
Commerce GA
Cmberges1
    May 31, 2024
    May 24, 2024
