question about 12db, 18db, 24db per octave
Steveopevo
could somebody explain the differences on how the different x-over settings on an amp affect the sound of the subwoofer. I was looking in to buying an amp and noticed some of the amps like the more affordable class of JBL and Boston amps only have 12db per ocatve roll off. is 18-24 really necessary?
A low-pass filter is a circuit that allows low frequencies to pass and cuts high frequencies. What's interesting is what happens in the transition between pass and cut.
Most filters do not simply pass certain frequencies, then suddenly at a certain point cut the rest of the frequency band completely. A so-called 'brick wall' filter is neither useful nor sounds good in most circumstances.
Instead there is a 'pass band' in which signals get through unaltered, then a gentle transition to the 'cutoff frequency' where the level is 3 dB lower than in the pass band. Then the response falls off further and further down into the 'stop band'.
If the simplest possible filter is constructed from electronic components - one resistor and one capacitor - then the rate at which the level drops in the stop band will be 6 decibels per octave.
This means that for each successive doubling of frequencies above the cutoff frequency, the response falls 6 dB. (This is the same as saying 20 dB per decade - a drop of 20 decibels for every tenfold increase in frequency).
A slightly more complex filter design can achieve 12 dB/octave; further increases in complexity can yield 18 dB/octave and 24 dB/octave. Oddly enough, in-between values are more complex to achieve, and therefore pointless to attempt.
The question is what use are these different filter 'slopes'?
A 6dB per octave slope is useful for gentle shaping - a little less bright, a little less heavy, depending on whether the filter is high-pass or low-pass. 12 dB/octave is more useful in a creative musical context. 18 dB/octave even more so as you can cut out great swathes of frequencies and hear hardly anything that you don't want left behind.
24 dB/octave is a little harsh for most purposes. It's like a cliff edge rather than a steep hill, and you can hear the 'edge' where the response suddenly starts to fall.
However in synthesis - subtractive ('analog') synthesis, then 24 dB/octave is perfect as it can remove high frequencies while still leaving 'bite' in the sound. Some synthesizers have filters with even steeper slopes.
Loudspeaker crossovers also have filters. 12 dB/octave and 18 dB/octave slopes are commonly used to separate bands of frequencies between woofer, mid-range and tweeter. The steeper 24 dB/octave slope is usually only found in PA systems where an active crossover (for which a 24 dB/octave filter is easier to implement) divides the frequency bands before the signals pass through to the power amplifiers.
where did you copy and paste that one from?
I find this representation of it very easy to understand..:
Cyan = 6dB/octave
Red = 12dB/octave
Green = 18dB/octave
Violet = 24dB/octave
he diagram above shows both high pass and low pass crossover filters with the 4 most common slopes. The crossover point is the frequency at which the level of the signal is 3dB down (for a Butterworth alignment - to be discussed later) from the level of the pass band (the crossover point is about 1000hz in this diagram). The pass band is simply the part of the audio band which is unaffected by the crossover's filters.
Copied this info from bcae1.com, great site if you really want to learn a bit more. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Steveopevo
Steveopevo
Silver Spring, MD
x2o
slater
    Oct 4, 2025
    Oct 4, 2025
