Question about 1000.1 TMA
joesf
Would the 1000 watt mono block TMA power my 12" W7 well or is the 3ohm weirdness that JL dose going to mess will the power output too much I know it will mess with it but what would I be pushing RMS to the one sub with this amp. 625?? Less??
I figured it would be about 625RMS but that would be a little better than my JBL 600.1 I had on it before I had 2 of those on 2 Adire shiva 12s (one each) If anyone has any suggestions for a amp for my situation it would also be greatly appreciated it was just that my local car audio store had the TMAs for like $280 or something under $300 so it sounded pretty good to be considering they are made by JL
look for a used pg amp, xenon 1200.1 or tantrum 1200.1. maybe a used jl 1000.1. I would put around 1000 rms to that sub or as close to that as possible
edit: even a used kicker zx1500.1 would give you around 1000 rms at 3 ohms. Theres a used one for sale in the for sale section for $250.00
You could probably even look into some 2 channels that are able to bridge at 4 ohms and be safe with a 3 ohm load a the amp... After imp rise, it would be in the 4+ range so it should be qble to do it... I would however look for quality brands if you plan on going this route... I know my older Kicker Ix2302 was fine bridged at 3 ohms to an older w6.. so probably a little over 900 watts
joesf
joesf
Alabama
Kold_Killa
BP1Fanatic
BP1Fanatic
