qts too low for door speakers?
Siguy
I recently ordered a pair of Dayton DC160-4 speakers to replace the factory woofers in the door. However, it didn't occur to me until after I bought them that the qts specification is only .33... I don't know that much about q-factor and such, but I know that people recommend at least .5 qts for in-door woofers. What is the effect of having an inappropriate enclosure for these speakers? Will they still perform better than factory woofers, or should I return them and order a pair of 8-ohm speakers with higher qts?
Or is there a way I can make the door behave more like an appropriately-sized enclosure?
They're to be mounted in my Saab 900SE, powered by a 125W 2-channel amp, with a 250hz low-pass filter. The factory 2-ohm speakers don't sound terrible, but not great either, and one of them has a bit of buzzing to it (which I can probably fix, if it turns out to be just something rattling around...)
You'll be fine.
A lower Qts can point to a preference for ported enclosure but, to my understanding, it changes anyway once mounted even if just slightly....
In my Personal experience, even low Qts mids I've tried did very well in my doors with good seals...definitely better than stock
Neither of those choices is optimal. The DC160-4 looks more like a small subwoofer with the Fs of 30.3 Hz and the FR of 30 - 4,000 Hz. The 6PR-8 won't give you much bass since the Fs is 75 Hz. A sealed or ported enclosure would help extend the bass response, but in a door you won't have that. This is a non-issue if you have a subwoofer.
As for "sealing" the doors, this refers to sound deadening treatments that specifically address the usual large access holes in the inner sheet metal. The door will never truly be sealed, but it can become a decent enclosure depending on your goals.
Either way, I installed them, and they're definitely a significant improvement from the originals. Of course, that's no surprise considering that the rubber surround on the originals had completely rotted away. There wasn't really any... speaker... left of those...
Siguy
Siguy
Massachusetts
Siguy
