Putting a wall in my scion xb. Let me know which setup i should run in it!
Xtremebass5
il
Im debating on either 4 15's or 2 18s. If i do 4 15s they will be some type of budget subs. If i go the 18 route they will be a little better of a woofer. let me know what you think and what subs i shall run. thanks tim
same watt & price? 2 18's ftw. but the amp and the box have a lot to do with it as well depending on what your going for. not much info here.
if i do 4 15s only looking to spend 200 each sub. So if i do 2 18s ill spend 400 each sub. what would be a loud budget wall?
4 15s is a LOT more cone area than 2 18s. I would go with the 4 15s personally. 4 SA15s on a Sundown 4500 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Just research the common suggestions of Fi, DC, IA, blah blah blah.
Personally, I'd love to see 2 18" SSA Xcons //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
Yup I replaced door speakers and just replaced rear speakers yesterday. What it was I had to adjust the crossovers
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
917
Xtremebass5
Xtremebass5
il
Xtremebass5
