pushing my sub too far?
loudenuff
WA gwon?
I got my big 3 done, now I have my brx 1400.1d wired up. voltage stays at 14.2, dips to 13.6 at most. I have 1 obsidian 15 wired to 2 ohms getting 900 rms but I can run it to 1 ohm and give it 1400.. if I'm gentle with my gain will it be okay? or am I better off wiring my 2 12 p3s to 1 ohm and play it safe? I'm not looking for a long lasting setup. just something to get me by until I upgrade to soundqubed.
If you have a single sub wired to 2 ohms than how are you going to make it into 1 ohm? What is the coil config on your sub? I would think d4 if you have it at 2 ohms? Which would mean you can only do 8 or 2 ohms with a single sub and if it is d2 you can do 4 or 1 ohm
no no it's a d2. I have it wired to 2 ohms but I want to wire it to 1. the p3s are d4s.
If it's D2, then you can only wire it at 1 ohm (parallel) or 4 ohms (series). D4 can only be wired at 2 ohms(parallel) or 8 ohms (series). You can also use a digital multimeter to check if you wired it correctly.
how exactly would I do that? set it at 1k?
I got it all set up now I have a new problem. voltage stays 14-14.5 all the time. 2 12s at one ohm make my lights dim like they're hazards. I set the gains down a lot and it only made a difference at the point where I couldn't hear the bass... so I took one 12 out. running it 900rms at 2 ohms. used dmm for tuning. and I'm still having dimming. did I do something wrong? I got a quote from singer but it's gonna take me 2 or 3 months to get that money together so I'm trying to work around that for now
250
402
514
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
826
531
loudenuff
loudenuff
WA gwon?
Jeffdachef
    May 18, 2024
    May 16, 2024
