Wiring Sq hdc3 12
I have a 2 ohm SQ hdc3 12 and I want to wire it down to 1 ohm. I know how to wire it but it's direct lead instead of push down terminals and I need advice on what would be best to use to connect the 3 wires for the positive together and 3 wires for the negative together. Any advice is greatly appreciated. Thanks in advance!
What should I use to wire them together? Like just test them together and then wrap it with electrical tape or how?
With something like the HDC3 I would used a custom box. Solder ring terminals to each lead and used bolts and washers instead of terminal cups. Jumpers on the outside of the box to reach desired ohm load.
Papabiz
Papabiz
Great bend ks
sciontistbb
vegang
vegang
