Pure silver wires?
Silver conducts electricity better than copper, are there any places were you can buy wires that are made out of silver?
Most people who do use silver would use silver or silver plated copper for their RCAs, but not for their speaker wire. If you're interested in silver plated copper, check out the seller "navships" on eBay, I buy all my SPC from him. Pretty much the best seller on the market, IMO. He DOES have some lower gauge silver plated copper if you want to use it for speakers.
http://stores.ebay.com/Johns-Silver-Teflon-Wire-Shop?_rdc=1
silver is ~$40 per ounce of silver, that would be over $100 for about a 40ft run of 14 gauge speaker wire. it would be well over $500 for a single run of 4 gauge from battery to amp. to add on top of that silver is not a pliable or malleable than copper. cutting 16 gauge speaker wire made of just silver would be difficult with cable cutters. there is just no real feasible reason to use silver considering that it does not conduct that much better than OFC to justify the cost. copper is barely $4 per ounce. the cost does not justify the results that's also why gold is not used on exhaust manifolds (except for the McLaren F1 and space exploration). this is also the same reason why sound deadening companies use aluminum foil instead of copper foil, if Dynamat used copper foil instead of aluminum foil it would deaden ~3x's better than aluminum. if you know the length you can usually find pure silver speaker wire at high end home theater shops, that are pre-cut and terminated.
Wingman0121
Wingman0121
Wisconsin Rapids, Wisconsin
CHEMMINS
michigan born
    May 14, 2026
michigan born
    May 14, 2026
