protect mode
my subs are 2 15" dual 4 ohm subs and i wired each one into 2 ohm and when both hooked up to the amp its supposed to equal 1ohm could it be because i turned the bass all the way on my cd player. and if its at rms i should be able to play it at that level all day right.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
You really need to take past advice and set your gains properly. No where in the tutorial does it tell you to turn the bass setting all the way up. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
little do you know, i did read the gain setting and set all my stupid gains right with the dmm to 34.6 which equals 1200 watts now your not understanding the question read this one more time and try to understand if its not to hard. now basicly is it ok to turn the bass on you cd player up or do you just leave everything at 0 or flat. get it now????????????????????//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
dude, you're a dick. READ my post. if you set the gains correctly, you would KNOW that the bass needs to be at zero.
at all times why cant you turn it up why does it have to be flat at all times.//content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif
He set the gain with the bass boost up on his HU, which is fine to do (according to all the threads I have read about it.)
Thank you someone understans me now .//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
caliece
caliece
chicago il
caliece
