proper way to disconnect subs, but leave amp?? (for a trip)
stophatin
but they cant stop my pay
hey guys im goin on a trip and need to make room in the trunk.
when i remove the subs, (but im leaving the amp) is it sufficient to just remove the fuse from the amp?
or should i actually unplug the power cable from the terminal block??? and disconnect remote wire?
all i do when removing my amp and/or subs is disconnect the fuse by the battery, unhook what i need to and just connect it back up but leave the fuse out, that is unless you still need your amp, then obviously put the fuse back in.
so its ok to just remove the fuse @ the battery when needed (changing sub/amp), and then replace the fuse when its all wired back up?? no sparks or ill effects????
might get a small spark but you will be ok
the "right" way to do it is to disconnect the neg cable on the battery.
THEN disconnect your amps power wire from the battery
When you ready to put it back, take off neg and then hook up the pos
stophatin
stophatin
SAN DIEGO CA
stophatin
