Yep, same car. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I've got kick mounted midbasses. I had to do quite a bit of experimenting with foam and MLV to get to a suitable place where I didn't have all sorts of issues traveling up through the dash.
I've not heard a car yet with all drivers mounted below the dash, facing toward the center console that had a stage height above the dash. Not saying it can't be done, but I've not heard it yet.
Based on that, and the appearance that his drivers are not pointed on axis, or even somewhat on axis, I have a feeling that he's going to have all sorts of issues due to reflection under the dash.
But, I'll hold my assumptions until I see how they're installed and aimed.
I agree, Aubrey, that he'd probably be better off to bring the tweeter and mid up top. Moving those away from the midbass isn't as bad as leaving the midrange down there with the midbass and having the tweeter up top. IM(short, limited)E, separating the midrange from the tweeter will give you some undesired problems that are harder to fix due to the typical crossover points used b/w midbass & midrange vs. midrange & tweeter. In general, it's just better to keep higher crossed drivers closer together.
