Project Vetkilr. Worklog with Pics. Plugged box that is 2.2 @ 29 HZ (for now)
iamamp3pimp
Bass Heads Entertainment
13,502
Tampa FL
Well to explain Pluggable..........for those that dont know, sometimes, with a test box, as this one will be, you dont want to rebuild every week for a daily driver, so what you do is make an enclosure with port plugs. you can remove the plug whenever you like, and replace it with another. evey time you make a new one though, you have to readjust everything, as the length/volume of the port, directly effects the internals of the box, because you cant change the walls of the box.
anyway heres the build log, for the box, and the first plug, that causes the box to be 2.2 cubes @ 29 HZ with 30 square inches of port area
Pics are for the win, right???
here we go
you cannot pass go. you cannot collect $200.
//content.invisioncic.com/y282845/emoticons/needpics.gif.edd6d28e76618c28c46f343991bcced5.gif
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif//content.invisioncic.com/y282845/emoticons/iagree.gif.15d6c075ee8d3913ba26866d06993068.gif
~Magick_Man~
Man hope one of those trees didnt fall on you and your puter:up2somet:
oh yeah and
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif :veryhapp: //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif :veryhapp: //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif :veryhapp: //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif :veryhapp: //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
As they all start, heres a full sheet.
Everything cut to shape...they almost look like they are posing
3 pieces togerher, the back, bottom and the side
a little closer
Showing off those corners...
see that PVC in the background?
it has nothing to do with this pic
Lookin pretty good there
More corner lovin........
yes indeed
the top is on
and even moreso
thats the basic cube all put toghether....now its time to cut out the hole for the sub, and the hole for the port.
the hole for the plug is a 10 x 10 square.
had to notch a little more out on the left side though.
different angles
TBH, that is too many speakers for just a pair of 10" subs. The Skar 6.5s and tweeters are very efficient and can get super loud on moderate...
940
I purchased a set of 1" stand off rings, should still be good from door to cone as well. They won't fit without the spacers, the recoils I...
30
8K
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Yes. It's one of those fundamental truths I somehow manage to unlearn every time I figure it out. :rolleyes:
I ran 2 10’s aero ported in my 06 mustang years ago. Each box was 1.2 and the subs were diamonds (can’t remember exact model). Best thing to do is...
10
iamamp3pimp
iamamp3pimp
Tampa FL
vetkilr
