Project PANDBASSA
Thank you all for the support and good advices //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Didnt boom today, just checked are the amps OK and system works, so ran about 1.5h on volume level 2 (35 max) with 2/3 sub level @ 50hz tone just to get the batteries flat ... Amps are fine and system works //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Some more things to do and full test either tomorrow or thursday //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
http://www.youtube.com/watch?v=coElkjxFpG4
he ran that set up briefly in 2002 and then changed up to the SOLO X 18sas for the angles and such its completely different variables in Extreme with a modified front cabin and Super Street and Street Max with a stock cabin.
Thank you. Dude went way back didn't he, lol:D
your box is 17.4cf? was that your total max? and i assume those are apxx's, but from what ive read 2 18apxx's like 24cf with about 340sq in of port.
just bustin your balls cause i want to run a 2nd apxx in a wall off 2 vfl400's... you just gota beat me to it. very nice build bud.
your box is 17.4cf? was that your total max? and i assume those are apxx's, but from what ive read 2 18apxx's like 24cf with about 340sq in of port.just bustin your balls cause i want to run a 2nd apxx in a wall off 2 vfl400's... you just gota beat me to it. very nice build bud.
Oh its 3-13 am here and im nearly sleeping //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
17.4 when subs in ... Can tell you the total size and calculations tomor ... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
These babies hit 164db in 18 cu ft with 15kw if i remember correct //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Class --> SS
Oh nooo
Box is peaking on 78hz ...
Didnt expect that ...
Yes that what i did with the port, made it as wide as possible and also calculated with BBP and got port tuning 64hz with the program ffs lol
Dont ask plz, the score was pure shait ... ok, around 30 degrees celsius as well in the car, but still ... seems i have to make the port smaller now
So around 17.4 cf box
port height 34.45 inch
what should be the width //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Double checked again and got 64hz tuning again on BBP //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Whats wrong ?
So far : things getting more weird for me ...
Made the port smaller, peaks between 68-70hz ...
car is same hot as yesterday and batteries charged, 154.8 when i was in ...
154.4 when out ...
wtf is wrong there ? ? ?
At the end of the day got 155.5 @ 68hz, similar with previous box ... removed the sunvisors, put the dynamat on few holes ... charged the batteries again ...
And i dont get wtf is wrong there ...
what is the thickness of the baffle? You need to round that.
its 50mm, 2" ...
i will round that but i cant believe theres 3-4 db behind that ... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
RookieMekanik
RookieMekanik
ireland
RookieMekanik
