Probly a Stupid Question...
Does it matter where the port faces? Most of the boxes I see have it firing the way the subs are but does it matter if it fires out the back or the side? Also, does there need to be a lot of room in front of the port?
No.No. Enough room to clear, and the port can go wherever it is most conveinent. Providing its the right size of course.
in a car - its been prooven that its best to have the sub facing the rear, and the port this way as well.
in a SUV - said to be up or rear is best...
hatchback, up\back is cool.
True, although that is simply optimal, there is no acoustic/physical reason why it can't go whereever the hell you want it to.
Sup man, just curious who has proven the fact that firing a sub and port rearward is better than any other direction. I ask because, well u know the install im doing. (which is darn near done, thank God) But anytime i asked people and down survey type things, i always seem to hear that firing rearward would be louder but the same or similar results could happen if u fire the forward and seal everything off from the trunk. I have yet to hear someone say firing rearward is best even if u seal off everything. I would really like to know where that came from because i really want this install to sound great
NJack2AF
Best Member Ever
NJack2AF
Las Vegas
KARLEON
michigan born
    May 14, 2026
michigan born
    May 14, 2026
