Problems with MB-Quart PCE-216 6.5's
skisloski
NY
Ok im going to try to describe my set-up in as much detail as possible so someone can tell me where i could possibly be going wrong.
I have an older head unit that works perfectly it has a 3-band eq. First place where i couldve gone wrong: the rca's leading to my component amp are plugged into the rear out slot on the back of my head unit and my head unit is recognizing my amp and speakers as a "sub" (ex. if i turn my "sub" setting on my deck up or down (-10 - +10) it also changes the overall volume of my components). My component amp is a 4 channel crunch brand amp. I know this isnt the best of amp's but it was cheap and it has enough power i suppose. I thought i needed a 4 channel amp to properly power a component set (my first time upgrading my speakers) but i guess i shouldve just bought a 2 channel. ANYWAY i have my components (MB-Quart PCE-216) wired to the amps channels 1 and 2. I have nothing hooked up to channels 3 and 4. My rear speakers are running off of my head unit.
Now the problems that im experiencing
With the level setting on my amp around 1/8 and the bass eq at dead 0 and the low pass properly set my mid-drivers sound and look like there about to blow because of too much power (my tweeters arent even 1/2 as they should be, and i know because if i put high pass filter on and turn my level up my tweeters sing like there supposed to, they are set to -3 on my x-over btw). I have my eq on my deck set so that the bass is at like -1 and it still is sending way to much power to my mids. And to make it even worse with my mids flopping arund like they are theres hardly any noticable pressure resulting from it. They are completely sealed off around my door panel. thats not really teh problem though, im not looking for a whole lot of bass out of them, i just want to be able to turn up my volume let my tweeters sing and still have my mids at a controllable power.
Also another problem is that when i change the fading on my deck from front to back and left to right my components are not affected, this probably also means that they aren't in stereo and sq is being sacrificed
Sorry its so long to read, im trying to be as detailed as possible so you can help me out here. I was really looking for a lot out of these components and so far im not impressed.
Any help?
is your xover switch on HPF?
try hooking the speakers to the bridged terminals on the amp, you will have to use a ch1/2 and 3/4 to use it bridged and make sure you switch mode switch to 2
how would that help solve my problem at all?
and no my xover switch isnt on hpf that would mean that my mids were getting no low frequencies, not too much power
i think im going to put the tweeters on ch 1/2 adn the 6.5's on ch 3/4 then i can better control them
hopefully this will help my problem.
still wish i could adjust between right and left fade and my hu wasnt seeing my whole component set as a whole
skisloski
skisloski
NY
skisloski
