Hey everyone, I installed a JVC KD-AVX33 today and it sounds amazing. I was looking at the instruction manual which seems to say although not clearly that the parking brake wire on the HU needs to be hooked up to the Positive(Not the negative) parking brake wire on the vehicle. Knowing this, I went ahead and hooked the wire to the acc wire on the vehicles wire harness together with the acc wire hooked up to the HU. The wire is working fine as the jvc turns on and off with ignition. the parking brake lead is tied into the same wire with a very secure connection. The problem is that the unit is not allowing me to watch dvd's because it is not detecting the parking brake. I don't know why the hell this is happening. I am supplying 12v to the parking brake lead like I am supposed to. I double checked everything and tested all the wires only to find everything is working as it should. The only thing possible is that the unit needs to have the parking brake wire hooked up to a ground. I have seen owners manual wrong before. What do you guys think? Thanks
