Problem with Rainbows!!
stealitall
Hey I got a problem +. I have CS 265 Profi Phase Plug in front and CS 230 Profi in back. What I can't understand is that the crossover keeps turning the Vol. down. I guess its there so it don't burn up. But what I cant understand is that the Vol is only hitting the half way marks and it lowers it self!! I have to turn the Vol down almost all the way so it can cool off. Do you think its HU or AMP the Amp is Brand new HU is about 4years. Need some info thanks!!! //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
If you are getting the protection kicking in so early in your volume range It sounds to be a gain related issue. Set your gains properly.
No way can a 'pair ' components' not get loud enough for you before HALO kicks in, running a single sub. My guess is the speakers are seeing more power/distortion than signal at that volume mark- possibly clipping it early in the HU's voltage range.
x2
well with the reputation rainbow has here i would be pissed too, i mean they are supposed to be absolutely amazing, and to buy all that and have it crap out like that would be a bit infuriating.
but 4 threads!
Yea 2 are diff from each other. One broke about 2 to 3 weeks later after the other one did. Plus I did not get a real answer for my Q that I asked thats why I asked again!!!//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif And yes other then the last one its diff its not becasue of the coils just becasue I have 2 still running and they still do it!!!!I have not got the other ones returned yet!!!
Perhaps learn from your mistakes. Keep xovers out of your doors and set your gains properly.
Thats not true the HALO protection was kicking in on my comps at even moderate volumes when they were first installed and while I am running a shit load of power to them my gains are properly set, I found a solution for that quick though. What does running a single sub have to do with the HALO kicking in?
Could he be preclipping at the HU? Loweryour gains on your amp. I know that this may sound stupid but since you did not set up your system make sure that the tweeters are actually wired to the right spot on the crossover. You are gonna have to walk through your set up from front to back.
stealitall
stealitall
easton,PA
stealitall
Mike Mccabe
