Problem with my ground wires
Dingyps
I have a 04 Hyundai Tiburon and behind the radio there is the wires coming from the radio and the wires from the harness...
Of course you are sposed to connect them and for my car the right side is sposed to be Gray and Gray with Black Stripe
So basically the whole right side of my car doesnt play music so I checked the speakers and used meters and all that, apparently no power was going to the door at all but there is some coming from the radio. So I tried to run my own wire from the radio to the door and they worked for a little bit and went out again... So I opened it back up and the radio is still giving off power but it doesnt give power if it connects to the ground wire..?
I can hold the power ones together and hold the ground to the top of the metal radio and it will play static, but if I put the wire on the grounding wire instead of the top of the radio, I get nothing...
Not sure why the speakers would play static either, I tried two speakers and both gave off static so I dont think it's a broken speaker.
Dingyps
Dingyps
Wisconsin
Kangaroux
