Problem with Dash Tweeter, Crackling feedback
  • 2
JeffreyG
I just got my sub & amp installed at and I'm noticing a crackling noise coming from the tweeter on the dash of my Jeep GC. I've had a blow tweeter before but it was different. This noise doesn't go away when I fade/balance to other speakers and it doesnt go away when the volume is at 0.
The install was good, the sub sounds great, and they even have the bass knob mounted flush on the center compartment. The only thing I can think of is that they hit the speaker wire when installing the amp to the HU or something. Any suggestions as to what happened?
Make sure all your wires are connected. Make sure they are in good contact and if that doesn't help, buy a ground loop isolater from Walmart or a better one if you feel you need it.
Grinder
you were right, my ground wasn't connected good. I connected it and made sure all my wires had good connection and its working perfectly now. Thanks for your help.
No, my friend had some rca wires on one end and jack on the other end. I also tried with 2 different rca wired from radio to the amp Yes, the amp...
173
Love the site, arguments over non-issues, not so much. ;)
13
89
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
858
JeffreyG
JeffreyG
New Orleans
Grinder1989
