Problem with brand new Sundown SAZ-1000D
Already tried this also . Might hook up my old kicker and see if it gets them moving
did you try it with both coils on one sub as the same time?
If the coils are somehow wrong, it will still do the same thing.
Try just using one coil from the sub or like you said use a totally different sub.
Its always possible that the amp may be bad but, to me, your description sounds too much like
the coils on the subs are wired backwards.
Is there any chance of a pic of the actual wiring of the subs?(the coils)
Just went out and tried my old kicker 10 and did the exact same thing. Might swap back to the old amp just to rule the rca's out
Fairly sure he doesn't have the coils wrong since he was swapping amps, not doing a fresh install. Meaning the last amp/sub combo worked and he didn't change anything on the sub end.
OP when I asked you to take a picture of the settings on your amp it was so we could see exactly how you have everything set. Take a look at your picture, how are we supposed to be able to read any of your settings?
Im thinkin the amp is dead. Tried my old kicker amp and it works great
I did change the sub end. Went from one kicker cvr to 2 idq 10's. And sorry about the picture. Camera is dead so had to use phone.
It is possible it's DOA but I'd still be interested in seeing the settings...
Even with a clear picture it is hard to tell what directions each dial is pointing. Here is what everything is set at.
Gain-0 and turn up when testing.
Subsonic- 0
lpf- around 80hz
bass boost-0
phase -0
See the problem with you just telling us what the settings are is that if your interpreting one of them wrong your going to tell us what you THINK it's set at, not what it actually is...
Correct me if Im wrong but all are set to 0 which would be all the way left except gain and lpf.
jmh51193
jmh51193
va
jmh51193
