problem solved!
  • Thread starter renier
  • Replies 0
  • Views 465
renier
Vivo BOoOM .i.(0_o).i.
SPECS
1x400W RMS at 4 OHMS 1x800W Max at 2 OHMS
1x2000W at 1.3 OHMS
Mono Block Subwoofer Amplifier
1 Ohm Stable
MOSFET Power Supply
PWM(Pulse-Width-Modulated) System
Glass Epoxy PCB With SMD Technology
Gold plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Variable Subsonic Filter(15Hz~40Hz,24dB/Octave)
Phase Control 0-180 degree
Input Impedance:10K Ohms
Soft Turn On/Off
Heavy Duty Power Coated Heatsink
THD: 0.1%
S/N RATIO: 90dB
Input Sensitivity: 200mv~8V
Freq. Response: 10Hz~150KHz
Remote Bass Control
Dimensions: 9.82''(W) x 2.34''(H) x 15.16''(L)
they replaced my recent amp w/ this..w/c i think it will drive my S15L7 solo baric at 2ohms w/o problems..
what do you think?
i hope they could return this 1week used baric dual 4 to the dealer and replace it w/ a dual 2 baric..
the box?i did calculations and designed it..i got 8cu.ft w/ all the displacement and 6cu.ft w/o the port..the port is 3.5" wide..and very long..i already forgot the measures..
i hope my system will shake some posers here at my place..
renier
renier
philippines
renier
