Problem setting gains on JL 300/2
mpbojangles
I've reset my gains about three times in the past week trying to fine tune my system. I tried to do it again for the final time, and now I am having a problem.
The DMM is displaying a very low voltage even when the gain knob is turned all the way up. I havent had this problem previously. Also, the batteries in the DMM are fine.
I am using a 1000 Hz -3dB test tone.
Any suggestions?
Per JL's site:
Step 1: Disconnect the speaker(s) from the amplifier.
Step 2: Turn “Off ” all processing on the head unit and the amplifier (bass/treble, loudness, EQ, etc.).
Step 3: Turn the input sensitivity control on the amplifier all the way down and switch “Input Voltage” to “Low”.
Step 4: Set head unit volume to 3/4 of full volume.
This will allow for reasonable gain overlap
with moderate clipping at full volume.
Step 5: Cross-reference the amplifier model used and impedance load per channel on the chart below to determine the target output voltage. For the 300/2 the voltages are as follows: 4 ohm=24.5, 3 ohm=21.2, 2 ohm=17.3, 1.5 ohm=15.0
Note: When bridging two channels, the impedance each channel works at will be one-half of the load impedance. Therefore, it is necessary to divide the actual load impedance in half and use this impedance in the chart when bridging two channels. Also, the voltage found in the chart should be doubled.
Step 6: Verify that you disconnected the speakers before proceeding. Play a track with an appropriate sine wave (within the frequency range to be amplified) at 3/4 head unit volume.
Step 7: Connect the AC voltmeter to the speaker output of the amplifier.
Step 8: Increase the input sensitivity control until the desired voltage (determined in Step 5) is delivered. If multiple subwoofer amps are being used, set each one to the same exact voltage and you have also level matched them. If excessive voltage is read with the control at minimum (full counterclockwise), switch the “Input Voltage” to “High” and re-adjust.
Step 9: Once you have adjusted each amp to its maximum unclipped output level, reconnect all the speakers and proceed to adjust the level balance between the subwoofer and satellite amplifiers by turning DOWN the input sensitivity controls of amplifiers that are playing too loudly. Do NOT increase the input sensitivity of any amplifier as this will defeat the purpose of this procedure by permitting excessive clipping (distortion).
If you do this and still have a problem, call JL Tech @ 954-443-1100.
mpbojangles
mpbojangles
Akron OH
BringDaBoom
