generalGOTCHA
Boyz in the Hood (EZE )
K here is what I am running
Orion HCCA 250 Digital Reference
2 10" Orion P series subwoofers.
Ok, I have a cheap battery lol.. from autozone. 1000 cold cranking amps, and shows 110amp reserve .. Is this horrible ???
Anyways.. from the battery I am running duel 5 guage wires.. Meaning I stuck two 5 guage power wires (best you can get at wal-mart) and wired them together trying to evade my little problem of eating up 100amp fuses.
Ok so I replace the fuse, and go bumping for a while.. setting the gain on my amp all the way down, and turning up all the bass options on my Pioneer DEH 7800MP color screen to louden the bass.
Note: I was to lazy to run a remote wire from my head unit to the amplifier lol. So I hardwired the remote to my power wire, and when I turn my vehicle off I just pull the fuse to not drain my battery.
So here is what I want to achieve !!!
I want to be able to turn the gain allllll the way up on my amplifier without it getting hot as hell @ 1 ohm btw. And play it all day without it melting the fuses up. IS THIS POSSIBLE ????
I can only get a 1 ohm or 4 ohm option from my DVC 10" subs.
They both will take easly 500Wrms.
Specs for this amp is 800Wrms @ 12volts.
So is it draining my battery ? then resulting in drawing from the alternator, and then heating up the powerwires weekest point being the in line fuse ???
I reallllllly am getting annoyed at this problem, and am willing to do whatever it takes, but want some technical perspectives on why this is happening.
