preblems with subwoofer
Looks like you used 2 wires for power and 1 wire for ground. Assuming that correct you may have heated up the ground side 2 much.Ground should be the same size or bigger. Try writing the company, even thought it's outside of warranty that may help you. If you get it fixed lower the fuse size and learn how to test ground resistance
the power and ground wire was the same and i used one for each of them, but ok, thank's for the tip, i will write them!
if i put 8A fuse instead of 10A, won't it bust out when i turn it on?
How much did you pay for it and how much are you willing to spend fixing it?
paid a long time ago and for a bundle, but if the problem now stands only the burned chip part, i don't think it should cost more than 20$ to get it done, or am i wrong?
dogy49
dogy49
Latvia
Jduane
