pre fab vs custom
In my experience a high quality custom designed enclosure can make a massive improvement to the sound of your bass over a prefab. You want to minimize enclosure resonances, as that not only sounds bad but it's wasted power. That means using better wood, not just the right thickness for your application but a good density to reduce air leakage. If it has to be a fiberglass structure there can be big differences in quality there as well. Getting the port sized correctly for your needs, and yes I do think you should go ported over sealed unless your sub "needs" a sealed enclosure, is part of the correct enclosure design.
I went went with a prefab box for my f150 it leaks air the cutout is a general size and unfortunatly for me my screw mounts dont line up that well took alot of time to just get all the screws to hold and it still leaks. spend the money on a custom box, prefab chances are your not gonna be happy and your gonna be out the cost of the box and then purchase a good one.
tford2244
tford2244
westfield
gimling
