PPI P1000.1 Wiring Question
96Firebird
I feel like an idiot for asking this, but the manual had me confused...
I have 2 SA-12 D4 subs, and want to wire to a final load of 1ohm. Reading this, it got me confused. Right now I am thinking I need to wire the subs in parallel (+ to +, - to -), then wire both + together and both - together, and then use only one if the +/- outputs on the amp. Does this sound correct?
Thanks for any help.
I think I got it figured out, with help from another forum as well.
Each DVC 4ohm sub can be wired in parallel to a 2ohm impedance, and then I can use both outputs on the amp. I could also wire it the way I said before, either way would work. Looks like the amp parallels the outputs.
But I do agree, they make it very confusing.
Thanks for the input.
It looks straight-forward to me. Most mono amplifiers with 2 positive and 2 negative +12V terminals have the like pairs of inputs joined inside the amp, which is why the "NOTE:" paragraph is included. Two 1 ohm subs wired in parallel results in a 0.5 ohm nominal impedance, which the amplifier can't safely handle.
  • Locked
I have aPC250on Ebay right now that works excellent couple days left on it at auction on the cheapies
I am wondering if anyone has heard or have information on the new PPI vertical PC amps. Are they good for a budget sq class D amplifier. Any...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG,16.2022 @9PM CT THANKS
96Firebird
96Firebird
Rochester, NY
trumpet
    May 12, 2024
Brendon Jenness
    May 11, 2024
