Powerbass ASA 2000.1d One ohm stable amp CHEAP
Awesome awesome amp! I've owned the asa1000.1 and the asa1500.1 and both amps loved 0.5 ohms daily and were efficient as hell! I clamped my asa1500.1 doing 2053 watts rms at 1.4 ohms (0.6 nominal) dropping to 13.4 volts clean power and my asa1000.1 did 1567 watts rms at 1.6 ohms(0.9 ohms nominal) dropping to 13.7. This amp will probably do upwards of 2.5k with correct electrical
i don't believe that, sorry. My 1500.1 did 1603 at 1 ohm rising to around 1.6 with stout electrical. A little bit optimistic on the 2500+ out of this amp
Hmm.. What clamp meter? And thats what mine did man... I used Fluke DMM and a Fluke Clamp Meter... I did set my gains with a DD-1 on a -15 test tone so then again you may have gone conservative on the gains.
I have this amp hooked up to a stinger spv-1700 1gauge wire good grounds big 3 and 200amp alt.. wired at 2 ohm's im seeing over 1000w .. Its rated at 2000 at one ohm .. this amp has always been hooked up at 2ohm+ never been been on.. Im sure it will put out some good power in the right setup I dont think you can beat it for 200 bucks..
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
zack39648
zack39648
mccomb, ms
zack39648
    May 20, 2024
    May 20, 2024
