Power HX2 Box for SQL
  • 2
Buckshot
Michigan
I plan on purchasing another power HX2 for the setup in the ol' venge, but I really don't know what the best SQL setup will be. I think I could get ~3.5cu ft, MAYBE 4 if I try real hard. I want to go with a dual ported setup, probably tuned to somewhere around 35 Hz.
How should I go about doing it? Seperate chambers tube ports? Slot ports?
a 3.5 cube box with both drivers stuffed in it and a common port?
Give me your input guys!
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
446
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
349
721
Buckshot
Buckshot
Michigan
ax600
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
