Power drainage
  • 4
Caddylover
I recently replaced the alternator in my 93 Cadillac deville, and since then I’ve been having problems with the car dying/not starting. Brought it back and the mechanic replaced the alternator, but the car would still die. He replaced the battery and the same thing happened. He replaced that battery, but the car would still die.
It’s weird because when I put my jumper on, it fires up and stays charged while I drive it around town, but if I turn it off without driving it a long time, it won’t start again. I recently jumped it and drove it around for a half hour without the stereo on and it would start up again after I shut it off. But if I let it sit a couple days, it won’t start. What gives?
audio/accessory power circuit is the cause of a parasitic drain more often than not. There’s really no help to be had he just has to track it down
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
409
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
316
668
With 6500 rms.. you are still going to need some battery bank and/or supply for that demand
17
Caddylover
Caddylover
Los Angeles
G35Cincy
    Apr 28, 2024
    Apr 28, 2024
