power cord
  • 2
If you're talking about wiring your head unit to the wiring harness, it'll still be the same as any other HU install. Match the colors. You could, however, disregard hooking up the green, purple, white, and gray wires for the speakers as they won't be needed if you're going with amps for all of them.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
589
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
433
johnthompson
johnthompson
Canton, Ohio
johnthompson
    May 20, 2024
    May 20, 2024
