power acustics 2600watt amp
  • 5
1996vortec350
it seems a little bit unusual to be running a nice pair of subs like that with a 2nd rate amp like PA, but if your Diamond's are the dual 4 ohm version the amp should match up ok. You'd want to wire the subs with the coils in series and subs parallel for a 4 ohm load on the amp (bridged).
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
539
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
729
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
556
1996vortec350
1996vortec350
alabama
DSHORT
