power acoustik
  • 4
Well the 15's will get "lower" then the 12's. And one good sub is better then, in your case 2 not so good subs. How much $ do you have to spend?...
I know there there not the best subs you can get. And they are pretty expensive for what they are. How much money do you have to spend on your subs? Amp?
O ok, then the two 12s (I believe) will be louder then that 10. The MOFO just takes more power, even though its not the much more...
EDIT: What model FURBs do you have? Single 4ohm, dual 4? And what model lanzer do you have?
Cable plugged in all the way? I know I had one and it didnt plug in fully unless you jammed it in pretty hard. Also, I suggest DS18 Bass Knob with...
I would consider a different brand. Whats your budget?
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
477
mulisharider10
Low Co. Motives
mulisharider10
San Diego, Ca
djjdnap
    Jun 1, 2024
    May 31, 2024
