Power acoustik SL-5500
SWEET06CAMRY
Hey guys
Since I'm looking for an amp that would do 2,000 rms @ 2 ohms but all the good ones I found so far are in the 700 dollar range //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I was looking at this one but the specs seem unreal.
5500 watts, Class D Monoblock Amplifier
RMS Power Output:
4 Ohms: 2100 watts x 1
2 Ohms: 3300 watts x 1
1 Ohm: 4200 watts x 1
High Speed Digital Circuitry
Fully Regulated PWM Power Supply
Four Way Protection Circuit
1 Ohm Stable
Bridging Synchronization
System Distress Indicator
Mono Speaker Output Connector
Variable Bass Control(0 - 18 dB)
Remote Dash Mount Low Level Gain Control
Nickel Plated Heavy Duty Power & Speaker Terminals
Dimensions: 22.3"L x 11.7"W x 3"H
1-year Manufacturer's warranty
Amplifier Specifications:
Number of Channels: 1 - Mono
RMS Power (4 ohms): 2100 watts x 1 chan.
RMS Power (2 ohms): 3300 watts x 1 chan.
RMS Power (1 ohm): 4200 watts x 1 chan.
Bridged RMS Power: Not Bridgeable
Peak Power Output: N/A
Min. Impedance Unbridged: 1 ohm
Min. Impedance Bridged: Not Bridgeable
THD @ Rated RMS Power: 0.50%
Speaker Level Inputs: N/A
Amp Preamp Outputs: N/A
Built-in Crossover: Yes - LP
High-Pass Crossover: N/A
Low-Pass Crossover: 50 - 150 Hz
Subsonic Filter: 15 - 40 Hz
Signal-to-Noise Ratio: 100 dB
Channel Separation: N/A
Bass Boost: 0 - 18 dB
Bass/Gain Remote: Yes
Fan Cooled: N/A
Fuse Rating: N/A
Warranty: 1-year Manufacturer's
Is this amp this powerful ?
3,300 watts RMS @ 2 ohms for around 450 bucks ?
Please guys I need input about this amp.
Thanks.
you can get a kx2500.1 from hi fi for only 500 shipped
Yeah but it's used and who knows what used amps have been thru //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
and the PA is brand new with a 1 year warranty..//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Is the PA worth the 460 bucks ?
Yes I have 2 0615'sL7's D2.
Nah dude,
Anything below 1 ohm gets way too hot..
I'm looking for power @ 2 ohms..
So you guys do not recommend it then ? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Yes I have 2 0615'sL7's D2.Nah dude,
I ran my MD2 at 1 ohm and it barely got warm //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
i was also looking at getting the sl-5500, but wisely decided against it. bottom line is you get what you pay for. if you really need that kind of power dont be cheap about. it probably puts out just shy of rated power but you will blow it, and it will run hot and you'll probably end up buying a better amp later on any way. you can find some real nice quality amp in the classifieds that are taken care of for reasonable prices. just keep an eye out.
SWEET06CAMRY
SWEET06CAMRY
SANTA ANA CALIFORNIA
casper97ta
