Post Your Box Specs Here:
Sub(s) w/ RMS: 2x 12" Lethal Injections, 500W RMS
Amp w/ RMS: Elemental Designs, 1200W@ 1 Ohm
Internal D x W X H: 11.25x19.5x14.5 (x2)
Wood w/ Thickness: 3/4 mdf
Chambers: 2
ft. ^3 per chamber (w/out displacements): about 1.85 ft^3
ft. ^3 per chamber w/displacements : 1.70-1.75 ft^3
Tuning Frequency: NA
Port H and W/diameter:NA
Port length: NA
Port extension:NA
Bracing: Chamber Seperation
Pics:
my crappy carpet job
i began to make this sealed box to maximize space in my trunk which it did, but when i got done i realized that i could have made it a little bit smaller. What do you guys think about 12" LI's in 1.75 cubes each sealed (recommended 1-1.75) ??? thats not to big is it ?? i was going to try it out when i get my subs in and maybe mess around with a smaller box later if i dont like it, but i hope it will be fine.
you can always throw some extra wood on the inside to lower the volume.(ttt for a helpful topic)
Here's the specs on my latest box.. It's a labrynth because the depth of the box needed to be 12.5" or less, and the sub wouldn't fit with 3.75 inches of port behind it.
Sub Type: 1 Orion H2 15.2
Box Type: Vented Labrynth (3/4" MDF Material)
External Box Dimensions: 17.5" x 43.5" x 12.5"
Internal Box Dimensions: 16" x 42" x 11"
Total Internal Volume: 7,392 in^3 (4.27 ft^3)
Total Port Volume: 2,605.44 (1.507 ft^3)
Sub Displacement: 829.44 in^3 (0.48 ft^3)
Useable Volume: 4,786.56 in^3 (2.29 ft^3)
Tuning Frequency: 33Hz
Port Mouth (Av): 16" x 3"
Port Length (Lv): 47"
Sub(s) w/ RMS: 3x jl audio 10w3s
Amp w/ RMS: soundstream 10.0 (800-900 watts)
External L x W X H: (5.5" x 8.5") x 56.5" x 16"
Wood w/ Thickness: .75
Chambers: 1
ft. ^3 per chamber (w/out displacements): i forgot
ft. ^3 per chamber w/displacements (Vb): 2.06cuft
Tuning Frequency: 33.9
Port H and W/diameter: 8" x 3"
Port length: 21.75"
Port extension: n/a
Bracing: none
Pic:
nowayhoser-newported1.jpg%20
it is too small. according to the owners manual the dual2-ohm should have 1cuft and 13" of port each. i disigned the box for two of the subs cuz of space restrictions...poly-filled...stuck in a third.
the port comes straight out the side opposite the speakers. i didn't want to deal with the ending the port on a sloped face.
genaric 3.2 cube @ 30hz box. will be about 3 cubes after sub displacement. so between 29~31hz depending on sub size //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the orange is a 4x8 sheet of MDF, the black lines are the physical cut lines for the saw, and their dimensions and names are listed //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hope that helps somone in this world.
bcarpenterfhl
Kiss Me I'm Shitfaced
bcarpenterfhl
San Francisco/Hillsborough, CA
bcarpenterfhl
