post denied?
ok, I am getting back into car audio now after years of just living with various stock set-ups. Last time I had a complete custom set-up was about 20 years ago and the subs I had required just over 2 cu. ft. each. the box was the size of a small coffin but I had a 1984 caprice classic so the box was maybe one third of the trunk space.
Now I am working on a 2007 PT Cruiser with the standard stock set-up, not the Boston Acoustics upgrade.
So far I have purchased Polk db6501 components for the front. the tweeters will go in the sail panel and not the stock 3.5" dash location. Polk db651s slim 2-ways for the rear door location and Polk dxi350 3.5" 2-way for the dash location. My sub is a Polk MM2124DVC, 12" momo. for amps I have a MTX Terminator TN400/4 and a Terminator TN250/1 mono-block for the sub.
none of this is installed yet, but as soon as some snow melts and the temp is a bit higher than 12 degrees, I will be elbows deep into it. I am going to use the stock head-unit and stock mounting locations throughout the car to maintain a somewhat stock appearance. I have found that this is the most basic and most cost effective theft deterrent known. NOBODY wants to steal a stock PT Cruiser set-up!
so now this brings me to three questions...
1. The MTX amps have "smart engage" on the speaker-level inputs that eliminate the need for line-level converters and a remote wire. This may be my inability to let go of oldschool misconceptions but... back in the day, some amps had speaker-level inputs for convenience and ease of setup but my experience was that the sound output was muddy and nowhere near the SQ if you used line-level. Is this poor SQ issue a thing of the past? should I not bother with line-level converters in the hopes that the SQ will be superior to speaker-level?
2. My interior set-up is going to be the db6501 components up front, db651s in the rear door, and the dxi350 in the 3.5" opening in the dash. The 4 channel amp will power the front and rear doors but the 3.5's in the dash will run off of the head-unit. my thoughts are that the dash speakers will probably be drowned out by the components... but... i was hoping that they might bring the stage up? any thoughts?
3. My sub is a 12" Polk Momo DVC. I know these subs are known for their SQ more so than SPL and that is fine with me. I want accurate responsive bass not boom. This sub though is recommended for small sealed boxes, .88 cu. ft. to be exact. the internal volume of the box I built is 8" x 15" x 14.25" giving me .99 cu.ft. My experience is that I can have about a 10% variance in volume with sealed enclosures with little to no SQ change. My real question is a two-part question... how well should i REALLY expect this sub to perform in such a small enclosure? and is my amp going to be enough to drive it?
the amp is an MTX Terminator rated at 200w RMS @ 2ohm. I have been told repeatedly by multiple sources that this amp is very clean and the 200w RMS rating is a bit underrated.
ANY answers will be greatly appreciated.
idk man, I don't see anything wrong with it...but to try and help you out.
1. I don't know anything about those amps so can't help you.
2. I wouldn't run some speakers off an amp and some off the headunit, the SQ will be large. I really think your better off upgrading your HU, the stock isn't going to give near the same SQ that a decent aftermarket one would.
3. What is the subwoofer rated at?
I was thinking about it but... the 2006 - 2009 PT Cruiser has a dash bezel that is not a standard 1.5 DIN, it has notches for the volume and tuning knob. its an accent to the stock HU but looks terrible with an aftermarket adapter.
its not just him, it wont let me post my questions either.
im no forum newb i used about 10 other forums and know how to work them. When the filter blocks link WHEN THERE IS NO LINKS in the post it kinda stupid IMO..... needs to be fixed
RocIrish585
RocIrish585
Rochester, NY
kgcolbyIII
