Possibly need a 18" sub for project.
3.5 he needs a 15 not enough airspace even for an 18 that likes small boxes I do have an ssd motor I could sell or build to a 15 for him.
I'd definitely go with a 15 in a proper box than an 18 in a box that's choking it. I'm assuming you have enough room for a 3.5ft^3 ported box after displacement...or is this for a sealed box?
That wouldn't be choking the mj18 they work well in 2.5+ it's just not IDEAL
3.5 ported...
In an 18" format look for a Qts of 0.25 or lower..... good luck with the 300 dollars unless its an entry pro woofer with next to no throw - which may work too.
most of these are about 1 grand. What you're asking for (if done right) is not cheep.
TC Pro 5100 Neo
Sound Stream XXX
Fi BTL (ask for soft spiders)
old school TC-5200 or Eclipse Ti Pro or any 4HP
IA Warden (again, ask soft spiders or the Q will be too high)
custom DC might work too, i think they have some super neo thing too.
B&C SW115 Neo
The second issue is a big enough port... You'll need a huge port and it will have to be long in that size box. Unless its going to stick out of the box a few feet then you probably have to do it with passive radiators.
45js45
45js45
lost.....again
RAM_Designs
