And you can estimate the "sound" of a sealed enclosure, it's called the total system Q. Larger sealed enclosures have better low-end response at the expense of less powerhandling. Smaller enclosures will have greater powerhandling, often at the expense of a slight "bump" in the frequency response. This is often described as a "peaky" sound, the driver being overdamped and not reaching full excursion at lower frequencies.That's not the question. The question is: Is it possible to estimate the possible gains from larger airspace? Also, I have already started construction of the box. It was originally meant to be ported, so its already got lots of airspace. So is there a certain level where the larger the volume, the worse the sound? How do I find that level, if it exists?
Optimal is often touted to be a total "Q" of .707 - there is a mathematical formula you use to determine system Q, but I can't recall how to do it right now.... it's 5AM and I'm up waiting for my cold medicine to kick in so I can go back to sleep. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Good luck!
