ported or sealed
well for spl,
sealed will require more power to run simply because of the restrictions of airflow. You can achieve spl with a sealed box to a point? Thats debateable too
ported is where it's at as far as i'm concerned for spl or sq. A properly designed port can sound good in just about any application, and yes it will require more cubic ft for your box, but in the end it all depends on the room you have to work with wether to port or seal your enclosure.
Sealed boxes typicaly will be more acurate thoughout a broader spectrum of hz....20-80hz .......ports are usually tuned to make one specific frequency louder than the rest. If a ported box is tuned to 60 Hz, 40 or 80 Hz won't be nearly as loud.
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
For what it’s worth… I picked up a mti stage 4 or 5 for around 900.00. Loaded with jl tw3 it’s was 1995.00. Which is a good 1k off what I would...
Assuming the taget curve is the same they will sound very similar. 2nd and 3rd order harmonics might be different but are offer hard to even hear...
😂😂 I actually have a CNC at my shop (I make drone parts for a living). It’s just that I got intimidated by all the tuning (equipment I don’t...
18
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
badm0f0
RIP DIMEBAG
badm0f0
Houston, Texas
ftgu
    May 22, 2024
    May 22, 2024
